Previous in Forum: Tensile Stength of Welding Materials   Next in Forum: Boiler Feed Pumps run by VSD
Air Release Valves
03/26/2009 6:04 AM
How the capacity of air release valves is calculated? Any standard or web link formula?
Pathfinder Tags: air release valve capacity
Re: AIR RELEASE VALVES
03/26/2009 6:11 AM
Is the subject "quick release valves"? These are provided adjacent to single-acting air motors so that the motor's chest is depressurised locally quickly rather than venting back through the air line and solenoid valve feeding it.
Here's a rule-of-thumb. In process work, if it happens in less than 1 sec, it isn't real. If the quick release valve won't vent as fast as that, then the chest is too large.
How quick does something need to be? And what is the something?
03/26/2009 6:21 AM
It is not quick release valve. These valves are normally on large pump discharge lines.
03/26/2009 8:22 AM
Ah! Understood.
Why is the speed of air release critical in this application?
Good Answers: 103
03/26/2009 8:17 AM
Do you mean Air Vent ?
Got a link, see whether it is useful
http://www.netafimusa.net/downloads/AG/A047_Air_Vents_Guide.pdf
Register to Reply 4 comments
b v rao (1); PWSlack (2); sb (1)
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
