Previous in Forum: Pigging Systems   Next in Forum: Cold Rolling in the Oil and Gas Industry
Roll Form Threads
03/26/2009 10:03 AM
Hi guys
Can a whizz on this site plz tell me the correct inspection pins for a 1/4 28 roll form thread g8 pre plate in steel. We are having quite a time trying to find this spec for tolorance on minor dia.
Also can someone plz inform me as to the difference between a b8 and g8 tap.
Thanks a lot
Kevin
Popular Science - Weaponology - New Member United States - Member - New Member Engineering Fields - Manufacturing Engineering - New Member
Re: Roll Form Threads
03/27/2009 6:27 AM
1/4-28 UNF 2B tolerances are the same no matter the method you use, Roll taps or cut taps. I know that Roll taps require a closer tolerance in the minor dia.(tap drill isize) for them to work properly. but the end product should be the same in size (Ø.215) Jim C
http://www.balax.com/
04/28/2009 5:20 PM
a G8 thread has a wider allowable tolerance band.
Register to Reply 2 comments
