Previous in Forum: Pre-Fab Material for High Temp Exhaust   Next in Forum: Best Material for a Natural Gas Line
Sizing a Vapor Extraction Fan
03/26/2009 2:57 PM
we have a vapor extraction fan connected to lube oil tank of Toshiba make steam turbine but we are facing problem with oil vapor ingression into turbine generator.
I suspect that the size of the blower is not able to handle and function to our requirement.
please suggest what could be the cause of this problem and the process of sizing vapor extraction fans.
Regards
Re: Sizing a Vapor Extraction Fan
03/27/2009 12:02 AM
Dear, First you need to check the volumetric flow and pressure of the selected fan, then try to calculate the amount of steam generated. Please note that as temperature of air increases, density decreases and amount of work done increases. And hence blower need to be design at higher temp. Hope this can clear your problem. Regards, Keyur Shah
First do it and then talk about it
Reply to Forum Thread
