Previous in Forum: Pad Footing for Portal Frames   Next in Forum: pile design for sandy soil
Transporting Grade 35 Concrete
03/27/2009 5:52 AM
What is the minimum time allowed to transport grade 35 concrete from the batching plant to placement site.I am located in the niger delta area of nigeria.
Re: MINIMUM TIME FOR TRANSPORTING CONCRETE IN A CONCRETE MIXER TRUCK
03/27/2009 7:08 AM
Doesn't it rather depend on the distance between the batching plant and the placement site, and the road speed limit in the area, Chief?
Good moaning!
03/27/2009 8:37 AM
It takes about one hour to get to the site from the batching plant. I want to know if this time and distance are allowable.
03/27/2009 12:26 PM
The answer to you question is contingent on what requirements you need to get from your concrete. Long time mixing of the concrete with water added to maintain the slump causes a loss of strength and other properties. Depending on temperature, materials, and job conditions, probably about three hours is a practical limit. You might have to run a trial batch to find out what you will get for strengths.
Re: Transporting Grade 35 Concrete
03/27/2009 2:54 PM
The ACI standards in US require placement with in less than 90 minutes after water is added in the plant, because any longer and to much of the cement has reacted and "set". I would specifiy a 90 minute time, and the time be checked by your onsite inspector, any batch that is not placed within the 90 minutes should be rejected and sent back to the plant. The contractor and concrete company will bitch about this when it arises, because it is a profit loss for which ever is responsible for the delays, but it is a good time to specify for a standard cement. (For rapid set cements or those with admixtures you may need to modify the specified time from water to placement).
03/30/2009 10:05 AM
The concrete on arriving site passed the slump test. Is it allowed to add water at site to be able to pump the concrete using the concrete pump? It is discovered that the concrete pump cannot handle the mix as it were.Would this affect the final setting strenght?
03/30/2009 10:40 AM
There are retardant additives that can extend the set time, perhaps this can help.
Register to Reply 6 comments
Anonymous Poster (2); charliemeka (2); Crabtree (1); RCE (1)
