Previous in Forum: Choke Flow - Restriction Orifice Plate   Next in Forum: instrumentation code and standard
Reverse Action Control and Direct Action Control
03/27/2009 9:06 AM
what is a Reverse and direct action?
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Re: Reverse and direct action
03/27/2009 9:13 AM
Download this .pdf for a basic explanation of reverse action control and direct acting control.
South Africa - Member -
Good Answers: 12
Re: Reverse Action Control and Direct Action Control
03/30/2009 2:33 AM
Hi there,
Reverse action - the opposite to what your signal is doing. i.e. signal increases but valve closes because air signal is removed in proportion to your input signal.
Direct action - signal increases - valve opens.
Download the fischer control valve handbook from the emmerson web site. Youw ill get a much better understanding of the principle.
Regards,
Craig
09/13/2024 5:52 AM
Reverse action example:
  • When the temperature rises above a certain setpoint, turn off the heater.
Direct action example:
  • When the temperature rises above a certain setpoint, turn on the cooling fan.
Register to Reply 3 comments
craigza (1); PWSlack (1); Steve Melito (1)
