Previous in Forum: EN8 Steel - Turning and Face Milling   Next in Forum: Standards
United States - Member - Member Engineering Fields - Manufacturing Engineering - Member Hobbies - Fishing - Member
Specification for A446 GRD-D Steel
03/27/2009 11:10 AM
Does anyone have the spec for A446 Grade D Steel?
I need to compare it to A653 Grade 50SS Class 1-G90.
Any info would help!
"Stepping up to the plate" is not enough, you have to swing to get a hit!
Pathfinder Tags: A446 A653 Steel Spec
Friend of CR4
Re: Need A446 GRD-D Steel Spec
03/27/2009 11:16 AM
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
