Previous in Forum: Substituting Metals   Next in Forum: Specification for A446 GRD-D Steel
EN8 Steel - Turning and Face Milling
03/27/2009 7:13 AM
Please tell me what will be suggested speed and feeds for Turning and face milling opeartions with respect to HSS tools and carbide tools?
Recommended speeds and feeds in SI units
Re: EN8 Steel - Turning and Face Milling
03/27/2009 12:58 PM
That depends on the Material your turning, the depth of your cut, the finish your trying to obtain, wether or not your using coolant and the type of cutter your using. There are books avalible to give you a place to start. But there is a "feel" to it as well.
The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair...Douglas Adams
03/27/2009 11:12 PM
Hi There are a basic guide for machining by calculation please refer to this website: http://its.foxvalleytech.com/MachShop3/SpeedCalc/SpeedRPM.htm
and :
http://en.wikipedia.org/wiki/Speeds_and_feeds
Basic :
HSS is High Speed Steel.........Normal cutting Tool for machining.
Carbide Tool ..... is Harder and can cut faster then HSS Tool.
Regards
patricktan
Register to Reply 2 comments
You might be interested in: Power Feeds, Turning Tools, Milling Machines
