Previous in Forum: make round hole square   Next in Forum: EN8 Steel - Turning and Face Milling
Substituting Metals
03/27/2009 4:44 AM
Can the material Fe-440 be used instead of S235JGR2 since S235JGR2 is not available in India.
Good Answers: 103
Re: Material
03/27/2009 8:11 AM
Check the application, there seems to be some difference in mech properties
YS 300 for DIN EN 10025 S235J (195-235)
TS 440 (350-510)
%E 22 (22-26)
Charpy 30 @500C (27 @20oC)
Use if your design permits these values .
Your material falls in between S275 and S355.
Check this. it may help you
http://www.corusgroup.com/file_source/StaticFiles/Business%20Units/CC&I/Products/Sections/Steel%20standard%20EN10025-04.pdf
Re: Material
03/28/2009 12:24 AM
Thank you sir.May i know what is your profession
Good Answers: 103
Re: Material
03/28/2009 2:13 AM
By education engineer. Service, upper management position in a very large engineering company.
What I suggest you is visit these two sites and they are very good for steel area
www.matweb.com
The first one will give you the properties of materials
the second one has lot of interesting articles. In fact if you go one step up in this you have non-ferrous too.
Canada - Member - Toronto, Ontario (South Parkdale On The Lakeshore) Engineering Fields - Marine Engineering - Great Lakes School Of Marine Technology (Owen Sound and Port Colbourne) Technical Fields - Architecture - Private Practice 1976-1990 Technical Fields - Education - Toronto Teachers' College 1971 Technical Fields - Marketing/Advertising - Founding Member Hobbies - Hunting - Founding Member Hobbies - Target Shooting - Founding Member
Re: Substituting Metals
03/28/2009 6:12 AM
Hi, dinakrj!
I'm in complete agreement with sb.
The application will determine whether two different alloys are similar enough to be employed, not their designation numbers.
Look them up, and determine whether they are similar enough from the point of view of the application (strength, corrosion resistance, reluctance, mutability, etc.) to be interchangable in yours.
What's your application going to be?
No simple answer.
Mark
03/28/2009 10:23 AM
It is just a support
03/28/2009 1:35 PM
Hi dinkarj!
I guess it's you telling me what the use of the alternative metal piece will be, since you would be the one to know, even though you show up as "guest".
Well then, bearing load related to compression (or tensile if forming a support beam) strength for starters. Keep saftey margins in mind.
Straight or bent beam or bracket or brace if you need to go to those extremes for length/size/load calculation.
Appropriate galvanic reaction times compared to supported item or shielding (if necessary) and fasteners with appropriate sheer strength to avoid galvanic response between new piece and fasteners.
It all takes just a few minutes, and probably when you know the answers, you can adjust the dimensions of the second alloy to match the strengths required in the first in case it is not sufficiently strong for its intended use with the same dimensions and install it with good life expectancy.
Mark
Register to Reply 6 comments
Anonymous Poster (1); dinakarj (1); MarkTheHandyman (2); sb (2)
