Previous in Forum: Specific K-Value for Fans and Blowers   Next in Forum: Potential Divider Criteria and Pot Selection
9V Battery - Hermetically Sealed and ATEX Approved
03/31/2009 8:33 AM
Looking for a 9 Volt battery that is hermetically sealed(?) to be used in a device that will meet ATEX approval for safety.
You reap what you sow.
Re: 9V battery ATEX approved
03/31/2009 8:45 AM
Provided the device enclosure is either EEx d or EEx p then any-old-battery will do. PP3, for example?
03/31/2009 9:35 AM
Thank you, I'm checking on the enclosure status now. I believe the enclose was not built with any rating in mind at the time. Anyway, thank you, Bill
03/31/2009 9:46 AM
If the enclosure was not built with any rating in mind, then the only stuff that can go inside it is Simple Apparatus under EEx i. A 9V battery, being an energy-storing device, is not Simple Apparatus. Therefore no battery would be suitable for the task.
http://en.wikipedia.org/wiki/Electrical_equipment_in_hazardous_areas
Re: 9V Battery - Hermetically Sealed and ATEX Approved
03/31/2009 3:03 PM
Check the requirements of the relevant ATEX standard, certain batteries can be used (in some cases and zones), BUT special requirements exist. You cannot buy a hazardous area battery and bung it in a box.
Check your standard to see what is and is not allowed.
Register to Reply 4 comments
BillV (1); jack of all trades (1); PWSlack (2)
You might be interested in: Battery Holders, Battery and Fuel Cell Components
