I have a project I designed where the existing plaster ceilings were removed in shower rooms inorder to replace piping, lights, ventilation, etc. New plaster ceiling are installed. The plaster is the standard Portland Cement-based. Curing is required before painting can be done. The paint manufacturer spec. states that the ph of the plaster must get to 13 before any paint can be applied. The ph goes from the upper 30's to lower 20's in no time but then it goes very slow. I have been told that no mechanical means of drying (fans or dehumidifiers) can be used. ASTM C926-98a does not cover this, other than adding heat in cold weather, etc. It is taking almost 20 days for the plaster to dry. I have 64 showers to do and the delay is killing the user. Can mechanical means be used to speed up the cure time? Any suggestions?
