Previous in Forum: AD-MERKBLATTER   Next in Forum: Dimensions for ASME A325 Bolts
Dust Collectors and Fume Extractors
04/05/2009 11:58 AM
Where could I get proper scrubber which can collect or dissolve dust as well as smell of product.
thoughts becomes things.
Good Answers: 243
Re: scrubber design
04/05/2009 6:56 PM
Sandeep, If you told us about the process and throughput someone here could probably help you.
milo
Good Answers: 101
Re: scrubber design
04/05/2009 9:08 PM
A wet scrubber will remove dust and gases. For more effective gas removal, add chemical reagents to the water to neutralize the dissolved gases.
Re: scrubber design
04/06/2009 3:20 AM
  1. What is the dust?
  2. What is the smell?
  3. What process is producing these?
  4. At what rate?
  5. What containment systems are there and why are these not working properly?
Re: scrubber design
04/06/2009 8:36 AM
Please send me your excet Working pressure and dust particle air flow, application where you want to use this scrubber. (For Dryer You want to use the scrubber)
Regards
Bhargav Thakkar
bhargav2684@gmail.com
Re: scrubber design
04/06/2009 1:49 PM
Dust partical bulk density is 0.59 to 0.63
and the dust is chilly powder which solvent I can use to minimize smell.
Bhargav please give me your contacts.
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Re: Dust Collectors and Fume Extractors
04/06/2009 9:27 AM
Try sourcing these products on http://www.globalspec.com.
Register to Reply 6 comments
Anonymous Poster (1); DVader1000 (1); Milo (1); PWSlack (1); sandeep lokhande (1); Steve Melito (1)
