Previous in Forum: EQUIVALENT MATERIAL OF MILD STEEL ;IS:2062 IN B.S.   Next in Forum: Material Equivalent to ISO 3183-3 L450QC
Inkjet Printers, Polypropyelene (PP) and Water Resistance
04/06/2009 1:55 AM
1. Printing should be done on the Polypropelene material with Ink jet printers like a.Primera Inkjet Printer, b.Bravo I , II , c. Canon 3500 , 5000 , 8000
2. It should get dried within 5 secs
3. After drying , when you touch it with wet cloth (or) when it is soaked with water - Ink should not get smudged or rubbed out
Kindly revert with your recommendations on Polypropyelene material and water resistant inks for the above or the equivalent.
Re: Inkjet Printers, Polypropyelene (PP) and Water Resistance
04/06/2009 10:47 PM
More information is required. Is the poly pro a film?
If so, then the film should be treated with plasma, corona, flame, or chemical treatment like fluorine or sulphination.
The difficulty printing on polyolefin is its low surface energy. As a rule of thumb one needs a 10 dyne/cm2 differnence between the surface energy of the substrate and the surface tension of the ink.
So, for your application you need to find a solvent borne ink that has surface energy of less than 20 dynes in a solvent that flashes off very quickly. I would say stand back because you are going to start some stuff on fire with this set-up.
Cheers,
Bloefeld
bloefeld
06/04/2009 11:07 PM
Sorry for late reply and i faced some technical problems continuously in accessing the blog.
The material is a label facestock and has to be printed in the inkjet printers, it has to get dried in a few, say about 30 secs. After drying, once it is splashed with water, the printed inks should withstand.
Is it a phenomenon related to the coating of the material or the printing inks ?
Register to Reply 2 comments
