Previous in Forum: PD 5500 and AD Merkblatter - Design Calculations   Next in Forum: Static Test for Water Tank
Cycle Time for Centerless and Internal Grinding
04/06/2009 6:03 AM
Here Everyone,
Here we are going to discuss abt the grinding methods in centerless, cylindrical and internal.
first let us know abt how we are going to calculate the cycle time in Centerless and internal grinding.
Engineers Comments Pls....
"Nothing Changes Unless Something Changes"
Good Answers: 103
Re: Manufacturing Technology Using Grinding Methods
04/06/2009 6:27 AM
1- machine spec ?
2. Wheel type ?
3. Wheel diameter ?
4- RPM ?
5- Job profile and rigidity ?
6- material ?
7- Dry/ Wet ?
8- Coolant ?
(it is already 5 days past the date)
Now let us talk about something simpler-
Let us calculate the turning time (on center lathe) required to machine a turbine rotor...
04/06/2009 6:34 AM
Good Answers: 15
04/06/2009 6:39 AM
Hello,
Let me add to SB's. Assuming good shop practices are being used. Calculate the volume of stock to be removed.
Allow enough stock for the grinder to set up and kiss-off the part. Leave only enough stock to clean up all surfaces with a safety factor agreed on with the grinder operator.
Remember to have good centers and surfaces to hold onto for ID and OD grinding.
Work out the stock allowance for centerless grinding with the CG operator also.
I like 2 tinker-no, really!
Re: Cycle Time for Centerless and Internal Grinding
04/06/2009 11:51 AM
For Centerless Grinding
Parishudh 200
Material : EN 21
Wheel Size : 500 X 250 X 304.8 mm
RPM : Not Sure Approx 4500
Wet
Cooledge SL Grade 1H 30
At present we calculate in meters...
We handle a shift for 8 hrs..in which 15 mins for setting..
140 Meters = (No. Of Passes X Length X QTY ) / 1000
I am not sure whether this calulation is right....Or otherwise some say that it can also be calculated through surface area.
OD = 60 ID = 60 Length= 100
Surface Area = (3.14 x D x L)/1000
04/17/2009 2:08 AM
Guyz kindly guide me whether can i use this calculation....
2tinker (1); PWSlack (1); sb (1); Sriram K (2)
