Need help!!
I have a sheet metal press shop having 4 power presses 10 ton to 150 ton capacity. We use different types of press tools on these machines for production. I am facing some peculiar problem in a Blanking Press Tool. Though thw part looks reasonably small, it has to be installed on 150 T Press, making it commercially not viable. We have tried routine tricks like surface grinding the press-tool, a proper maintenance of the press tool etc. to no avail. The press tool is mounted on a "Pillar Set(or Die set)" which is itself, freely working.
I am not a mechanical engineer. I remeber way back about 15 years, I had come across a formula which can be used to calculate the force required to cut metal sheets by using parameters like perimeter, thickness of sheet metal, Young's Modulus etc. to provide the blanking force required on a Power Press.
I have tried various combinations of search words on "Google" without any success. Can any one help me on this?
