Previous in Forum: Instrumentation in hazard area   Next in Forum: introduction to real time
Solenoid Valve with Metering Screw
04/06/2009 4:39 PM
Hello,
I am looking for a Solenoid valve that has a metering screw on it. Its a Normally Closed (NC) valve, two way valve 1/4" or 3/8" female threads. 110V power to it.
The one that i could find was from Kip INC. here is the website with all the info on the valve:
http://www.dultmeier.com/products/0.689.2209/2360
Part # i am looking at is 3X529-10.
They are giving me a 4 week wait time but i need this faster then 4 weeks. Does any one know where i can get something like this in North America.
Thanks
Mustafa
Re: Solenoid Valve with Metering Screw
04/06/2009 6:42 PM
If you want something quick, why not separate the valve and metering functions?
Good Answers: 123
04/06/2009 8:46 PM
As stated above, using a separate metering screw assembly attached to a solenoid valve would make it easier. What is being metered through it?
ARO Alpha makes this design valve, plus a few others that might work. Clippard, and Red Hat are other brands I remember of this design.
Bob
04/06/2009 10:48 PM
You can contact M/s Bhaskari Aqua products - HYDERABAD for the solenoids they are indian partners of T&P Italy..
Ph : +91 04023073032
Good Answers: 123
04/07/2009 7:39 AM
Think, my good man, think.
The one you want is 110 volt.
They have a 110 V valve with no metering valve under part # K1359015-10, and they have a 24 V with the metering valve built in to it, with # K13X293.
Buy both of those valves, which they show as in stock. Change the coils and you will have a 110 V with metering valve, and a 24 V without metering valve.
Good luck to you.
Bob
04/07/2009 7:09 PM
if the 24 v is DC then the core tube would also have to changed out as DC and AC core tubes are different.
Bin there, done that, then done that again and again and now I forgot where I was.Is this what it means to get old?
04/07/2009 10:41 AM
THanks to all of those who replied...
John DG: I cannot seperate the flow control valve (metering screw) from the Solenoid as this is for a pressurized system.
This valve needs to be open .25" when NC so some water could go through it and also cause back pressure for the
RO membranes to produce water.
Bob C: Water is being metered through it and thanks for the supplier list, i will contact them today and as for me thinking
dont worry, i always think before i act. I called them to ask them if the coils are interchangable. They told me not
its not, but thanks anyways.
Good Answers: 123
04/08/2009 12:02 PM
Both listed as AC.
Bob
Register to Reply 7 comments
Actlabs (1); bob c (3); JohnDG (1); MIKE L. (1); VC KRISHNA (1)
