Previous in Forum: cable size calculation   Next in Forum: Beer Goes in and Beer Comes Out
Circles and Radii - Converting 2D to 3D
04/07/2009 8:30 AM
Help in converting a 2d drawing to a 3d drawing. How to fit a radii in the outside of a circle.
I have a cam track cut into the outside of a drum. At a certain degree around the outside I begin a lift in the cam. it stays at that lift then falls after a total of 47 degrees. The problem is I know the degrees, the appx. angle of lift, the center (top of lift) and a approx. radius of the start, top of lift, and end. I drew this as a 2d drawing and it works out fine. However when I try to convert to 3D or we program in the points in the Mazak it doesn't work out. I need help as my job depends on this. I can send a dwg. if necessary.
Sh** doesn't just happen, we engineers make it happen!
Pathfinder Tags: CAD solid model
Re: Circles and Radii - Converting 2D to 3D
04/07/2009 9:12 AM
I havnt made sense of your description. Are you going to draw a 3D model from 2D blueprint, or imput date of 2d to cnc in order to process parts?
what project are you using in your 2D drawing? I think you d better post out your picture here. if your pic is dwg file, [you seem to use autocad or some relative software]. try to poste.in jpg format
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
04/07/2009 2:19 PM
The Mazak is obviously a machine tool. If programming in the points doesn't work, there must be something going wrong in the translation process. Maybe a consultation with the machine's manufacturer could help.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
04/07/2009 9:50 PM
thats out of my depth. I hant operated machine.
04/08/2009 9:29 AM
When a 2D drawing won't convert to 3D, a common problem is with intersections that don't actually intersect. If the lines extend past one another or end short, the 3D program cannot make a solid model.
Zoom in close to the intersections and use a 0 radius fillet to join them and try again.
04/08/2009 9:40 AM
It was a intersection problem. Thank you all that helped out. Now I just need to get a copy of solidworks so I only draw in 3d!!!
3Doug (1); cnpower (2); HarryBurt (1); mcarlson (1)
