Previous in Forum: Mid-Week Challenge: What Is This Device?   Next in Forum: An Interesting Approach to Fusion
32 comments
Brain Twister: The Distance Between Two Walls
04/08/2009 11:31 AM
There are two walls and a floor.
A straight stick, 40' long has one end placed on the corner of wall left and floor and the other end leans on the wall right.
Another straight stick, 30' long rests one end on the corner of wall right and floor and the other end leans on wall left.
That is the sticks cross each other.
From the intersection the height perpendicular to the floor is 12'.
Find the distance between the two walls.
The walls and sticks are in the same plane
There is a tide in the affairs of men. Which, taken at the flood, leads on to fortune; Omtted, all the voyage of their life is bound in shallows and in miseries
Good Answers: 101
Re: Brain Twister: The Distance Between Two Walls
04/08/2009 11:40 AM
infinite number of solutions.
Or... It could be earlier than my normal brain operation time.
04/08/2009 11:48 AM
Nope. Only one.
Good Answers: 101
04/08/2009 11:52 AM
is there something left out? Can the sticks cross at any point as long as they cross @ 12' perpendicular to the floor?
Looks like I'll need to get a cup of Java before i 'll loosen by brain Rust.
Good Answers: 101
04/08/2009 11:55 AM
oops.. i see what i did wrong... I failed to recieve all the information... told you its too early for me today... somehow i missed: leans on the wall right/left.
--------------------> off to get coffee
04/08/2009 11:57 AM
+- 340' ...I think.
Dreams are the blue print for reality.
04/08/2009 12:52 PM
The answer must be less than 30' so that the smaller stick can lean on the other wall. I'll say 18'.
04/08/2009 12:54 PM
23.217'
04/09/2009 5:55 AM
Excel Solver???
Can you put in the Math
04/09/2009 10:36 AM
Nah, no math. I'm an engineer - I used CAD. Took about 5 min.
04/08/2009 1:16 PM
Are the sticks perpendicular to the walls (as viewed from above)? Are the walls parallel to each other?
"The walls and sticks are in the same plane" doesn't seem to make sense.
04/08/2009 1:29 PM
can you make a drawing?
04/09/2009 5:24 AM
refer to the drawing of Mike or John above and below your question
04/08/2009 1:34 PM
04/08/2009 6:55 PM
... or even this?
http://cr4.globalspec.com/thread/7412
Mike, well spotted - GA!
Doorman and Guest (#7), you may (I don't know) have the correct answer to the question Dedaelus intended to pose, but (as I think RVZ717 suggested in #1) the question actually posed has no solution.
04/08/2009 7:15 PM
Hi JohnDG,
I think we're talking that Dadaelus meant to/should have said "the two ladders are in the same plane which is perpendicular the the common plane of the walls". That, or some reasonable variation, is how I would have described it.
Thanks for the GA (I just remembered beating by brains out trying to work the algebra in the thread by JohnJohn you just linked)!
Mike
04/09/2009 5:38 AM
That is right and your diagram is also correct. I do not know how to get a sketch in here. Creates a problem to explain w/o a sketch
You can call me Ray. Easier.
04/09/2009 10:05 AM
Sparky did a great little tutorial on posting graphics:-
http://cr4.globalspec.com/thread/15743/How-to-insert-Graphics-into-your-Post-to-make-it-more-readable-or-interesting
If you want a good free 2D CAD package I recommend TurboCad LE:-
http://selectfreeware.com/node/269
You then need any free screen capture tool to grab the picture and save it as a .jpg
04/10/2009 10:37 AM
Thanks for the link
04/09/2009 5:20 AM
The answer to http://cr4.globalspec.com/thread/7412 is very easy.
I do not know how to get a Diagram in here but there you go:
Your problem is:
A 32' rod from left corner leans on right wall
A 27' rod from right corner leans on left wall
Distance between two walls 24'
What is the perpendicular ht. from intersection to floor
let it be X
let the dist. from where 32 rod leans on right wall to the base be B
let the dist. from where 27 rod leans on left wall to the base be A
B=(32^2-24^2)^0.5 = 21.166
similarly
A=(27^2-24^2)^0.5 = 12.3693
let the horiz dist from left corner to the line coming down from the intersection on the base be: Y
so the horiz dist from right corner to the line coming down from the intersection on the base will be: (24-Y)
from similar triangles
Y/24 = X/B = X/21.1660 and
(24-Y)/24 =X/A = X/12.3693
solving for X and Y
Y = 8.8525 and
X = 7.8070
your answer for dist from intersection to base is X = 7.8070
If you want you can draw it and and check it out.
In my problem the dist from intersection to base is X is known.
you have to find the dist between the walls
No wonder your prof smiled at you
04/09/2009 3:37 AM
Yes. That is the diagram
For a general solution one can use the ladder lengths as A, and B and the Perpendicular distance from intersection to base as C. These are known.
Solve for length between walls X.
Please note that if you know X, A, and B; C can very easily be solved so the answer to this problem is unique
A similar problem is:
In an isoscles triangle prove that the equal angle bisectors are equal. Easy to prove.
but if put the other way:
If the angle bisectors are equal in a triangle, prove that the triangle is isoscles can only be done by reductio ad absurdum method.
Had lots of fun in school foxing the geometry teacher.
04/14/2009 3:09 AM
Aha, we had that one on CR4 some time ago too: after a lot of thought I came up with this "contradiction" proof:-
http://cr4.globalspec.com/comment/20093/Re-Isosceles-Triangle
I didn't get any feed back. Do you know a simpler method?
04/08/2009 3:28 PM
I think GUEST #7 is pretty close... I have 23'-3", but am still working the math.
04/09/2009 10:30 AM
Its 23'-2.601"
04/09/2009 12:30 AM
There is no ceiling - just two walls and a floor. Both sticks lean ON their respective walls not against them. The the overall length of the sticks shouldn't matter. They intersect at 12ft. The distance between the two walls at the base should therefore be 24ft
Son, do you see the bird? The archer: No father. Son, what do you see? The archer: His eye, father!
04/09/2009 7:27 AM
i think i got dumber reading that...
if your walls are 12 feet apart, your intersection will be alot higher then as if your walls were 24 feet across
put 2 straws together and find out.
04/09/2009 8:59 AM
ha ha ha...yO! ssinnett, it's OK - you now can get reading classes for free in most places. If your over 24!! This is an English class trick question - has little to do with math. More like geometry. ON vs AGAINST - no ceiling ?
04/09/2009 9:45 AM
just stop, you've made yourself sound even dumber
04/09/2009 11:19 PM
READ #19. The distance between the walls is 24 ft like I said. The perpendicular from base to intersect is 12 ft. how mush more do you need? Sorry, didn't mean to aggravate you. But I will stop anyway just to be courteous to you.
04/13/2009 7:26 AM
number 19 isnt the same as this one. lol
number 19 is talking about the link he posted, and the height for that one is 7 feet, not 12.
your still off.
Engineering Fields - Chemical Engineering - New Member
04/09/2009 2:47 AM
I agree with 23.217'
I kinda cheated and used the microsoft excel solver to iterate the answer. I guessed a height up the wall by dividing 12 by some fraction. That fraction representing where the intersection occurs between the walls. (eg. 1 being the intersection at the wall and .5 being halfway between the two) For the other stick, I used 1 minus this fraction.
Using pythagorean theorem: distance between walls = sqrt(stick length^2 - calculated height^2)
I used the solver to minimize the differences between the calculated differences changing the intersection location.
I know there has to be a way to do it with trig. I tried a few times but gave up. Could anyone enlighten me with the real way to solve it?
Dan
04/09/2009 4:15 AM
23'
04/09/2009 4:28 AM
23.217 is the right answer.
The problem can be solved by either trignometry or similar triangles. But the final equation ends up in a complex form with underroot.
So iteration becomes the easy way to solve.
Assume angle A and B.
X be the distance between wall.
Cos A = x/40 Cos b= x/30
tanA= sqrt( 1-cos²A)/Cos A= Sqrt( 1-(x/40)²)/x/40
x= 12/Tan a +12/tanb
So you end up with a complex formula which can be solved by iteration.
Alternate method is use similar trianles.
Height at which stair touches the wall H1, H2
H1= sqrt( 40²-x²) h2=sqrt(30²-x²)
l1,l2 be the intersetion length
l1+l2= x
l1/x=12/h1 l2=12/h2
So you get an equation 1= 12/h1+12/h2
Iteration will give the solution.
Register to Reply 32 comments
Anonymous Poster (4); Barnie (1); danman285 (1); Dedaelus (7); Doorman (1); JohnDG (2); Mikerho (2); narendra54 (1); pianohands (1); Quobaldt (1); Randall (2); RVZ717 (3); ssinnett (3); WOODROOSTER (3)
You might be interested in: Retaining Walls, Curtain Walls, Floor Locks
