Previous in Forum: Elastic moduli of Wolfram   Next in Forum: Aluminum Crystal Size
11 comments
United Kingdom - Member - Member
Gas Volume - Total Air from a Stack
04/09/2009 7:33 AM
Gents, a question from a colleague,
He has 80 cubic metres of air at 170 degrees from one source, combining with 30 cubic metres of air at 80 degrees from another source exiting from a common stack. What is his total volume of air coming out of the stack
cheers
Al
If you remain calm while all those around you are losing their heads, then you haven't realised the seriousness of the situation
Re: Gas volumes
04/09/2009 8:39 AM
Assuming it to be an ideal gas (air isn't) 111m3 @ 145degC as a first approximation.
Good Answers: 103
Re: Gas volumes
04/09/2009 9:01 AM
Where is the calculations ?
PV/RT ?
So GAs Rule
Re: Gas volumes
04/09/2009 10:17 AM
<...Where is the calculations ?...>
In the bin!
Re: Gas Volume - Total Air from a Stack
04/10/2009 12:25 AM
Provided that air's pressure is almost ATM and there is no change in pressure while mixing in stack.
Temperature change = (170x80+80x30)/(80+30)= 145.5 degree.
So, 170 degree 80 m3 air is cooled down to 145 degree while 80 degree 30 m3 air is
heated. Cooled gas will withdraw and hot gas will expand. How much?
Vol = 80x(273+145)/(273+170) + 30x(273+145)/(273+80) = 111.001 m3
Hope it will help you!!
04/10/2009 9:23 AM
...and that's how another annoying homework was completed!
Good Answers: 103
04/11/2009 3:25 AM
No this OP does not seem to be a college guy (at least from his previous posts )
04/11/2009 11:46 AM
I am curious here about the inconsistency between the volumes (80 + 30) used for calculating the mixed gases Temperature and the final volume (111.001) calculated with the mixed gases temperature. I have the curious feeling that the two volumes should be the same.
EditorGBAnalysts - Give a boy fish and he will eat may be for a day, but teach him how to fish and he will eat everyday.
Good Answers: 103
04/13/2009 12:04 AM
These are very rough approximations. As PWS already informed.
The actual accurate will be non-ideal gas and iterative.
As the first step, let us mix the gases as liquid
so the final temp
T'= (v1T1+v2T2)/(v1+v2)
= (80* (170+273)+30*(80+273))/(80+30) = 418.45oK=145.45oC
Now based on this approx T calculate back the individual volumes as
V1/T1 = V2/T2
For the first stream
80/(170+273) = V'1/(273+145.45) or V'1= 75.56
Similarly for the other one, V'2=35.56, the addition comes out to be 111.1
Then you have to do a re-iteration based on this modified approximation. But since the variation is not high (110-111.1 is only about 1%), we can almost take it as final value (espacially since the main base of calculation - ideal gas - itself is wrong)
04/13/2009 12:48 AM
The temperatures of the two gases are so far apart that I thought the implicit approx on the density in the energy balance was too rough, but it does not matter I guess. I got 141 for the temperature and 117 for the volume, but that is also first approx so I thought I might ask. However, being less than a 10% error perhaps it does not matter.
But thanks for the further clarification.
04/14/2009 2:26 AM
Wow!
04/14/2009 3:29 AM
Thankyou all for your input into this question, an approcimation is adequate for our needs and the information will be passed on to my colleague.
Once again, thanks
Al
Register to Reply 11 comments
Anonymous Poster (1); Bolton_Alan (1); editorgbanalysts (2); PWSlack (3); sb (3); yeonhoyu (1)
