Previous in Forum: Rotary Screw Engine?   Next in Forum: Exchangers height
Force / Preload vs. Torque
04/10/2009 7:21 PM
If I am using a screw to push a load, how do I calculate the load I get from a given torque? I don't think it is the same formula I would use to calculate clamping force or preload in a screw, is it?
Good Answers: 183
Re: Force / Pre-load vs. Torque
04/11/2009 4:10 AM
You can use same formula if you have the right ones considering the fact that the torque in an assembly depends on two friction zones:
-head or nut
- thread
In your case you have to keep the term for the thread friction and adapt the second to the way the contact on the contact surface is build up.
Re: Force / Preload vs. Torque
04/12/2009 10:50 AM
What formula are U using?
04/12/2009 3:08 PM
Good approximation can be found in "Mechanical Engineering Design" , Shigley, Joseph. See section 6.5 to 6.6 Or any other engineering text.
04/12/2009 4:37 PM
Nook Industries has some calculators for these.
http://www.nookindustries.com/Engineering/Calculators.cfm
phoenix911
04/13/2009 11:52 AM
http://www.wilcoxeng.com/tools.html
Here's another calculator that lets you select the fastner, type in the torque, and it returns the force. See the lower one on the linked page.
Half of everything in life is counter-intuitive,,, I'm not sure about the other half yet...
Anonymous Poster (1); Curious George (1); D C (1); nick name (1); phoenix911 (1)
