Previous in Forum: difference in symbole representation   Next in Forum: residence time
Current unbalance in VFD drive by G5 yaskawa.
04/11/2009 2:43 AM
Dear Sirs,
we have installed 18.5 kw vfd drive and we have observed that cureent pahses are at no load 4.6amp,4.8amp and 3.1amp. But resistance is balance in all three phases and insulation level is also high. This is only one example i am citing here.In general all the vfds installed here are showing this type of unbalancing of current.
i will be pleased to know why is it happenenig?
Re: Current unbalance in VFD drive by G5 yaskawa.
04/11/2009 8:36 AM
The reason may be the unbalanced voltage between 3 phase of your supply system.
04/11/2009 8:47 AM
voltage in supply system is balanced and it is 409v,410v,404v.
04/12/2009 5:01 AM
is it new motor or rewound motor?.
Good Answers: 80
04/12/2009 11:23 AM
At low load, the 4-6V of voltage imbalance that you have is enough to produce a small current imbalance. ~1A imbalance is negligible on a approx 20A drive. Don't worry about it unless it reaches 5-10A at full load. If it does, look for the reasons for the line voltage imbalance. The drive is not likely to be the cause for the current imbalance. The line voltage imbalance is more likely it.
04/13/2009 11:20 AM
u must check the incomming supply voltage
if it is unbalanced
04/13/2009 1:16 PM
Voltage at source can differ from voltage in motor winding due to resistance in the supply circuit cable terminations. This could cause a difference in current values.
05/10/2009 4:36 PM
please check the incoming voltage if it is balance, considering that the motor have balance resistance and high insulation in all three (3) phases. If it is found unbalance, expectedly the current will have too.
Register to Reply 7 comments
Anonymous Poster (3); dpandey1 (1); lavurk (1); marcot (1); spghadei (1)
