Previous in Forum: Ph level questions   Next in Forum: metallurgy for Steam Coils in a Sulphur Pit
on structure of matter and phase transitions
04/11/2009 1:47 PM
I have some philosophical questions that arouse from my MEMS lectures.
What force makes matter to have liquid and solid states and in solids what force makes the necessity of crystal lattice.
My second question: Isn't entropy at elementary level enough for the particles to emit the heat(radiate it) so they don't have to perform the Brownian movement?
I heard very small structures have totally different volume to surface ratio so this is my excuse in involving entropy in my second question.
Thank you very much!
Re: on structure of matter and phase transitions
04/12/2009 10:56 AM
First question - Free energy does the trick.
Second question - Entropy causes Brownian motion.
04/12/2009 3:07 PM
Is your primary interest why some compounds are gasses and others are liquids at the same temperature and pressure? That has to do with the molecular weight of the compound and the degree of intermolecular bonding energies. Oxygen, Molecular weight 32 and Nitrogen, Molecular weight 28 (diatomic molecules) remain gasses at very high pressures and low temperatures. There is very little intermolecular bonding in these molecules. Helium, Neon, and Xenon, monoatomic moecules are very light, do not display intermolecular bonding, and are very dificult to liquefy. Methane, Molecuar weight 16 takes a fair amount of pressure and cooling, while Carbon Dioxide, Molecular weight 44, is easily compressed and cooled to form a liquid. Ammonia, Molecular weight 17 is even easier to liquefy, and water, Molecular weight 16 is a liquid under standard conditions. The order of intermolecular bonding energies is CH4<CO2<NH3<H2O, so that the very strong intermolecular "Hydrogen" bonding in water due to its physical dipole shape creates the energy to bind it into a liquid.
Register to Reply 2 comments
You might be interested in: Crystal Filters, Force and Load Sensors
