Previous in Forum: Anyone know how accurate is the www.polymerdata.com?   Next in Forum: on structure of matter and phase transitions
Ph level questions
04/11/2009 8:21 AM
I have been wondering about Ph level in my HHO device. I am using a solution of KoH about 1lb to a gallon and when I check the Ph level with test strips it is off the chart. I am sure there is a way to measure the Ph level, but am unaware of local sources for this testing. It is only for my information and not to prove anything other than trying to isolate components in the solution due to the electrolysis of water. I only use distilled water, but I am sure there are still trace elements in it. Also. my early designs were inefficient and produced a lot of iron oxide from the cathode. The mixture was saved from these tests for later analysis. I would like to compare the old solution to the new solution and identify the components in both.
Anyone know how that is done? Thanks.
onecraftydude
Pathfinder Tags: hho ph level
This discussion was "closed" on 04/12/2009 3:15 PM. No new comments are allowed.
Message from admins:
Possible/likely scam. To those invested in these products, please produce independent verification that they work or stop posting. No excuses about "suppressed technology", or comments from “users” who have supposedly purchased it. New posts must start with independent verification or be deleted.
Good Answers: 243
Re: Ph level questions
04/11/2009 1:44 PM
04/11/2009 9:02 PM
Thanks for the link.
onecraftydude
04/11/2009 5:25 PM
Here's a reply from one of those engineers unfortunately encumbered by a surfeit of training and knowledge, and therefore unsuitable for inventing innovative new technologies which contradict all that obsolete old knowledge.
A pound of potassium hydroxide dissolved in a gallon of water produces a roughly 2 molar solution:
atomic mass of K = 38 gm per mole
atomic mass of OH = 17 gm per mole
atomic mass of KOH = 38 gm/mole + 17 gm/mole = 55 gm/mole
1 lb KOH * 454 gm/1 lb = 454 gms of KOH
454 gm KOH * 1 mole KOH/55 gm KOH = 8.25 moles KOH
1 gallon = 3.785 liters
8.25 moles KOH/3.785 liters H2O = 2.2 molar
pOH is the negative logarithm of the OH ion concentration:
pOH = - log 2.2 = -0.342
At room temperature, the relationship of pH and pOH is given by:
pH + pOH = 14
This implies your pH is above 14, which is impossible, but it clearly shows you are, as you say, "off the chart." It may be that you cannot dissolve more than a certain amount of potassium hydroxide in water, that above the molarity that would yield a pH of 14, the KOH simply doesn't dissolve anymore.
But the bottom line is, your measurement is accurate, and it isn't due to any impurities; it's just the amount of KOH you poured into the water.
04/11/2009 9:08 PM
There are 2 different solutions. 1 has a pound of KoH and that is what I am using right now. The other had sodium hydroxide and iron oxide from the annode that it was destroying. The reason I want to test this fluid is the consistency of it. There is iron in the bottom of the jug that separated out but the water is still greenish almost like a 50/50 mix of antifreeze. It is more curiosity than anything with the old mix, but I would like to identify the saturation level of the new mix so I dont waste KoH.
onecraftydude
Register to Reply 4 comments
emc_c (1); Milo (1); onecraftydude (2)
You might be interested in: pH Transmitters, pH Electrodes, pH Instruments
