Previous in Forum: Fabrication   Next in Forum: Equivalent European Steel to ABS/DNV Grade Steels
Ally spot welding
04/11/2009 10:57 PM
Can someone tell me how to spot weld aluminum?
"A designer knows he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away."
Re: Ally spot welding
04/12/2009 10:58 AM
"how to spot weld aluminum?"
Type the above statement into a browser
After you've read some of the tons of published data already available, if you have questions on the subject, come on back.
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
04/23/2009 6:35 AM
hi cool,
the info can be found from:
American Welding Society
Welding Technology Corp.
HTH!
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
04/23/2009 8:04 AM
Thak you, this was very useful.
Good Answers: 58
04/25/2009 7:35 AM
you're welcome.
see the "Rate" button underneath my reply? I'd appreciate your clicking on it and giving it a "good answer". TIA!
05/04/2009 4:33 PM
Sandwich the Al between two small pieces of sheet steel. Try for a shorter time than the steel wold have required. This is for sheel Al. The resistance of the steel enables the heat to be generated to form a weld.
Anonymous Poster (2); langyaw (2); lyn (1)
