Previous in Forum: tyre manufacturing plant   Next in Forum: Ally spot welding
8 comments
Fabrication
04/11/2009 1:42 AM
In order to make a tank of diameter 2520 mm the length given in my drawing is 7870mm.Is this correct or not.
Good Answers: 15
Re: Fabrication
04/11/2009 1:56 AM
No
I like 2 tinker-no, really!
Good Answers: 97
Re: Fabrication
04/11/2009 2:24 AM
the 7870 may be correct.
If 7870 is divided by pi you get 2505 which is only 15 mm smaller than 2520.
What is the thickness of your material?
Is the 2520 inside or outside diam of the tank?
Good Answers: 103
Re: Fabrication
04/11/2009 3:15 AM
If the plate thickness >= 30mm then correct. However no allowance will be there.
As hendrik has correctly calculated - the diffce is 14.90mm
The rolling (mid point) diameter for this plate will be 2505mm and thus a 30mm plate will just get the OD of 2520 but not the ID.
Re: Fabrication
04/11/2009 3:29 AM
I don;t know - does rolling stretch plate too?
Good Answers: 103
Re: Fabrication
04/11/2009 3:50 AM
Yes they do, on OD and the ID is under compression.
Re: Fabrication
04/13/2009 4:17 AM
My Plate thickness line is 15mm
Hobbies - DIY Welding - pipewelder
Re: Fabrication
04/12/2009 8:00 AM
I would add an extra 2% to the length dimension. You can cut the length off allot easier than you can weld a piece on after you get in the field.
pipewelder
Good Answers: 22
Re: Fabrication
04/12/2009 11:52 AM
Depending on the type of roller you are using, you may need to allow for the "initial pinch" flat spot that results from getting the sheet started into the roller assembly. As the previous poster pointed out, it is easier to trim than add.
Register to Reply 8 comments
2tinker (1); Anonymous Poster (1); dinakarj (1); Doogleass (1); Hendrik (1); pipewelder (1); sb (2)
