Previous in Forum: Nasir A   Next in Forum: Thermal contact conuctance(TCC) measurement set up
Swaged Nozzle Design as per Section VIII Div. 1
04/12/2009 1:48 AM
Dear All,
I am designing a swaged type of nozzle (one end cirular and one end ellptical). Is there any specific method to design such type of nozzle as per code?
Currently I am designing it Considering the walls of nozzle as welded flat plate and using formullie of UG-34.
Thanking in Advance.
Good Answers: 51
Re: Swaged Nozzle Design as per Section VIII Div. 1
04/12/2009 2:38 AM
Use this formula for the minimum thickness of elliptical nozzles:
t = Pa2b2/[SE(a2sin2Φ + b2cos2Φ)3/2]
Where:
a = major radius of the ellipse, in.
b = minor radius of the ellipse, in.
E = joint efficiency factor
P = design pressure, psi
S = allowable stress, psi
t = thickness, in
Φ = as defined in picture below.
(Don't forget to add any corrosion allowance to that minimum thickness)
Taken from the Guidebook for the Design of ASME Section VIII Pressure Vessels
A little knowledge is a dangerous thing.
04/13/2009 9:37 AM
Can you cite a source or derivation for your minimum thickness of elliptical nozzles formula? For use in the Code, U-2(g), "good engineering practice", would need to be invoked and the geometry would have to be not covered by any of the Code rules.
The Code, ASME Section VIII-1, Appendix 13 "Vessels of Non-circular Cross Section", does not directly deal with elliptical cross sections (it covers obround, stayed, and rectangular cross sections).
Good Answers: 51
04/13/2009 3:13 PM
Yes, (the link was given)
ISBN #: 9780791802397
Published: 2006
Publisher: ASME Press
Which credits the theory of elliptical cylinders (Flugge, 1967):
  • Flugge, W., 1967, Stresses in the Shells, New York, Springer-Verlag
04/13/2009 11:06 AM
Thanks a lot XMech !
Register to Reply 4 comments
Lawrence (1); Mechie (1); XMech (2)
