Previous in Forum: brake drag   Next in Forum: Car Bumper Manufacturing
Lubricant Substitution - Safe or Sorry?
04/13/2009 1:14 AM
Hi all there
Who could introduce me a site or a way to find the equivalent of a special oil of a company from another company?For instance what is the equivalent of "shell tellus c 220" in "TOTAL company" products?
Re: oil equivalent
04/13/2009 1:40 AM
There are tables of comparisons available but I would strongly recommend against using them if you do not know what you are doing. By far the best way is to know all that is needed to know about the equipment that you want to lubricate and then choose a lubricant from a reputable manufacturer to suit that duty.
The original equipment manufacturer's (OEM) recommendations are a very good place to start. After that a good lubrication engineers advice is useful (not many of these guys are any good never mind which oil company you use) and then read the specifications for yourself and decide what is best for your equipment.
Good Answers: 196
Re: oil equivalent
04/14/2009 1:12 AM
Follow the manufacturer's recommendation if you can. If the equipment manufacturer sells some special stuff for lubricating your equipment go ahead and expect to buy that or do some good engineering to find a substitute (after the warranty is done).
On the other hand the product recommended may be just what's written in the literature or website and is simply another company's brand name lubricant.
Contact the equipment manufacturer and ask them if they can recommend an alternate brand.
If the recommended lubricant has a generic spec in its description like "SAE xxxxx" or "NLGI xxxx" then another lubricant manufacturer will likely have an alternate they can recommend especially if you can give them a more specific description of your application.
A lubrication engineer trying to recommend a lubricant will likely be interested in:
1. the type of machinery,
2. what kinds of bearings, gears, and other moving mechanism parts it contains,
3. operating temperatures both highest and lowest,
4, corrosive dusty or wet conditions in the environment,
5. hours of use per day, week, or year
6. duty cycles,
7. frequency of maintenance opportunities,
8. monitoring methods for machinery condition in general and lubricant levels in particular,
9. consequences of breakdowns,
10. quantities of oil needed at maintenance intervals,
11. methods of lubricant delivery both to the machine and within the machine (could be anything from a squirt oil can in the hands of an operator to a centralized pumped and filtered lubricant distribution system for an entire system.)
Note that the old line oil companies in the USA like Exxon-Mobil, Shell, Texaco, Chevron have long had industrial lubricant product lines. A lot of good application engineering capability applicable to large machinery (like over 3-5 hp) is available there. Their local industrial lubricant distributors will likely have ready access to that body of information or at least be able to tell you how to find it on the internet. (try to sound like a maintenance engineer or foreman when you call them).
Ed Weldon
Re: oil equivalent
04/14/2009 8:43 AM
I can see a couple items that you missed.
12. Is the lubricant being cleaned through any type of closed loop reuse process?
13. What environmental requirements (e.g. small or large quantity generator of hazardous waste status, EPCRA 313, etc.) is the company willing to work with? Are there any soy based or water based lubricants that will meet the application specifications and reduce environmental requirements?
"We cannot sow thistles and reap clover. Nature simply does not run things that way. She goes by cause and effect." Napoleon Hill
Re: oil equivalent
04/15/2009 3:48 AM
Could you give me some types of theoe tables?
Thanks
Re: Lubricant Substitution - Safe or Sorry?
04/14/2009 3:42 AM
04/27/2009 11:04 PM
All colleagues above are right. I need to add that commodity lubricants are made with the same additives and same specifications. If Shell Tellus Blank is an HLP according DIN 51524 part 2, then any hydraulic under that spec should be the same quality and can substitute the other lubricant regardless of the operating conditions in the machine. Just ask the Total rep for a product accoding the spec you require, or the one that is specified by the OEM.
There are also tables for equivalent products in the premium synthetic lubricants group. Get them at www.lubritec.biz
Register to Reply 6 comments
Anonymous Poster (1); Ed Weldon (1); moheshams (1); Otto34 (1); Randall (1); WWkayaker (1)
