Previous in Forum: renewable energy resources   Next in Forum: reduced tee fittings
11 comments
Wanted: Multi-Stage Pump
04/15/2009 2:19 AM
I am looking for a pump to meet the following could anyone help or recommend a pump that will meet these specs
A. Pump Flooded suction Raw water
550 meters length of pipe (150NB line)
450m head (static head)
70-90 litres per second
Single stage or multi stage
Motor 550 volts
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Re: Multi stage Pump
04/15/2009 2:23 AM
Hello
Have you a technical specification for this pump? Is not a difficult application. Send me this spec to find the right pump.
Look over to the next challenge
04/15/2009 3:43 AM
The motor voltage is a bit unusual. Other than that, there should be any number of pump suppliers ready to assist. It's a bit of a biggie as regards power consumption at around 0.5MW, and it may be that a higher voltage motor is preferable. The starting gear for it will be an interesting exercise too.
Good Answers: 103
04/15/2009 7:08 AM
As per your 70-90 lps, the pressure drop in the piping will be about
8 - 13m /100m = 44 - 71.5 m over 550m length
http://www.engineeringtoolbox.com/pressure-loss-steel-pipes-d_307.html
(for 6" line)
So you need a head generated say 450+71.5 = 521.5m assuming this is the head that you need and not the vertical head - else add the pressure you need at outlet side.
That makes it about 52 bar
http://www.lenntech.com/unit-conversion-calculator/pressure.htm
Now you have to get hold of a pump that has these characteristics.
And yes the power at just below 500KW seems to be a bit high.
04/17/2009 1:20 AM
it is worthwhile considering enhancing delivery pipe diameter to reduce friction loss; this will have reduced power demand resulting in motor of lesser kilowattage; this also means reduced recurring expenses in power bill. the most important of all - your equipment's carbon footprint will reduced - a great environmental initiative.
yes: you will need a multistage pump for this head or hook up two pumps in series; best is to consult a manufacturer or a technically competent manufacturer's rep.
upsidedown
Re: Wanted: Multi-Stage Pump
04/15/2009 4:16 PM
What is "raw water"? Is that like "sweet water"?
04/16/2009 10:51 AM
This is underground water.
04/17/2009 1:11 AM
raw water is unfiltered water as it is sourced from borewell, river, pond, stormwater etc
upsidedown
Good Answers: 196
04/17/2009 2:45 AM
Pumps this large tend to be fairly specialized for the particular service they are used in. If you are a serious potential buyer of a new pump for this service then you are best advised to contact one of the large established pump manufacturers.
Sulzer, KSB, Flowserve, Goulds, Clyde, Flowchem are all big names worth contacting for this type of multistage centrifugal pump. These pumps are usually in what is called a "barrel pump" configuration for horizontal above ground installations. A common application is as a boiler feed pump for a large electric generating station. There are also large deep well multistage pumps that have similar configurations and performance; but are packaged for vertical mounting in a well casing with a vertical shaft motor or a horizontal shaft internal combustion engine and right angle gearbox at ground level.
When you talk to a sales engineer or an application engineer you will be asked for a lot more information on the proposed pump installation and service than you have chosen to give us here. Best be ready for that.
Ed Weldon
04/20/2009 7:54 PM
We can do that with a verticle turbine pump
and you can have it in pretty much any material you want.
A proper spec would be appreciated and any required specs that need apply combined with certs required
Good Answers: 196
04/20/2009 8:22 PM
GreatSage -- Way back when I worked at Worthington Pump (yup, 1963 and a bit later) the folks that built the vertical turbine pumps were in another division, so I never got close to them. I've always had the impression that if the application and especially the siting of the pump was right an electric driven high pressure high flow water pump was less expensive in total cost as a vertical turbine design than a horizontal pump particularly the horizontal split case types. Horizontal barrel pump designs were not all that popular at the time. What's the real world view today?
Ed Weldon
04/20/2009 8:52 PM
Ed
Good to hear from you. There is a lot of misconception about pumps and all I can say is that in truth I do supply a lot of VT pumps over between bearings or Horizontal split case. When you were with one of the proper pump companies that over engineered pumps so that they are still going many years on without much fuss, that concept is alien today. The VT pump has a much better rage on high head applications than that of a Split case Horizontal which are predominantly high volume movers. However Ed the cost of the VT pumps is high $50k cheapest I have supplied. The thing is that you can't get a horizontally mounted pump that will reach the high head applications that the VT pump will achieve.
regard
Register to Reply 11 comments
Anonymous Poster (1); Ed Weldon (2); GreatSage1963 (2); PWSlack (1); sb (1); sikazwej (1); upsidedown (2); user-deleted-1104 (1)
You might be interested in: Stage Lamps, Vacuum Greases and Vacuum Pump Oils
