Previous in Forum: Heat load calculation for transformers   Next in Forum: Thermocouples and Valve Actuation
Grounding System for Substation
04/15/2009 12:18 PM
How should I design the grounding net work of a 33KV/415V ,50hz indoor substation?
Indoor Dimension:20mx20m.with concrete floor,soil resistivity 20ohm-m.
System description: 33kv supply from Sate Board will feed the 33KV inddoor sus-station.Source end is located at a distance of 5km from the indoor sub-station.No other details at source end is available.
Connected load details:-
A. 1.2MVA,33kv/570V ARC furnace transformer,Z%=5
2. HV: delta,LV1:star;LV2:delta
3.Vector group Dyn11 & Ddo
B. 1. Auxiliary transformer 33kv/415V,capacity 500kva;Z%=5;Dyn11,.
Note: Touch,step and mesh voltage should not be greater than the tolerable limit.
Ajoy Chatterjee
Good Answers: 140
Re: Grounding System for Substation
04/15/2009 11:08 PM
By picking up the Yellow Pages and looking through them for a competent engineer. The kind of info you need will not be found here.
04/16/2009 12:28 AM
suggest purchase the earthing code published By Burro of Indian standards which will give you all the information you need good luck
04/16/2009 6:50 AM
Ajoy
Please go through the following to understand the subject.
1. IS-3043 Code for Earthing
2. IEEE - 80
3. IEEE - 142 Green Book
And as the volatge levels involved are very high it is recommended to hire a competent design engineer/ consultant.
Atlas Shrugged - JGD
Register to Reply 3 comments
Anonymous Poster (1); Current Maarey (1); North of 60 (1)
