Previous in Forum: Engineering Failures and Excessive Vibrations   Next in Forum: What am I doing wrong?, springs
12 comments
Biogas and Internal Combustion Engines
04/16/2009 1:34 AM
I am a 4th year mechanical engineering student At Tribhubhan University, Institute of Engineering, Pulchowk Campus, Nepal. I would like to do project on Internal combustion Engine Running with Bio Gas. IS it good idea To pump water Using THe BIO GAs From Toilet OR It will BE more Costier THan Electricity OR it will NOt be technically POssible Please suggest me.............
Re: Using BIO gas for running Internal combustion engine
04/16/2009 3:00 AM
It is done in larger municipal sewage works, to generate electricity that is both consumed within the works and exported to the local grid.
04/16/2009 4:33 AM
Biogas is also used for process heating within a sewage works. Surplus gas is sometimes simply burnt off at a waste gas burner. The surplus gas is the resource otherwise available for electrical generation for export. The economic viability of it depends upon the tariff agreed between the works and the local electricity utility company, and the price of investment capital.
09/11/2010 11:13 PM
cummins flywheel housing
4060861
cummins flywheel housing 4060861
cummins fabricated parts flywheel housing,cummins flywheel housing use for Trawlers engine , cummins flywheel housing of shipping diesel , cummins flywheel housing for Ship cummins
4B3.3 housing,flywheel
QSB3.3 housing,flywheel
4B3.9 housing,flywheel
ISB3.9 housing,flywheel
ISB4.5 housing,flywheel
QSB4.5 housing,flywheel
6B5.9 housing,flywheel
ISB5.9 housing,flywheel
QSB5.9 housing,flywheel
ISB6.7 housing,flywheel
QSB6.7 housing,flywheel
6C8.3 housing,flywheel
ISC8.3 housing,flywheel
QSC8.3 housing,flywheel
Good Answers: 101
04/16/2009 3:51 AM
Technically, it is possible. What you need is a biogas digester to ferment the wastes to produce the biogas. Whether it is feasible or not depends on how much wastes you have.
04/16/2009 4:33 AM
check with general electric in austria, i remember they are using this tech. and you can take a general Idea from them if you cntact them, i have a presentation for this I can send it to u
Good Answers: 18
04/16/2009 6:06 AM
I believe that the GE product you are referring to is JENBACHER in Austria.
They have many engines operating on land-fill gas as well as 'clean' NG. Fermenter derived gas is an alternative to the other fuels but may need conditioning to achieve a stable calorific value.
If it ain't broke,leave it well alone .........until it comes looking for you!
04/16/2009 8:33 AM
Canada - Member - BC Born, Alberta Raised, Quebec (poutine) crazed... Engineering Fields - Aerospace Engineering - An airplane is just a bunch of beams... Hobbies - Model Rocketry - Had fun as a kid...fun stuff Hobbies - CNC - dreaming of cutting Engineering Fields - Control Engineering - PID ME!
Re: Biogas and Internal Combustion Engines
04/17/2009 7:15 AM
Has anyone ever farted in an engine's air intake to see what happens? seriously...gas engines can be modified to run on natural gas (from the ground, that is) or propane. If you filled your tank with biogas, is there enough energy density to run an engine.
Driving into taco-bell: "filler up!"
kkjensen
04/17/2009 9:27 AM
Try researching Wood Gas. You also might check out this web site AllPowerLabs.org
All power labs has designed a wonderful little wood gasifier that is built just for the bio gas researcher. And it is not limited to wood you can put anything that will burn in it.
And to answer your question is it possible yes. This type of fuel has been used for years.
Good luck with your research.
Hobbies - Target Shooting - New Member Hobbies - Fishing - New Member
Good Answers: 12
04/17/2009 9:30 AM
Waste Management Corporation in the USA is a leader in tapping methane from landfills. It is used in special large Caterpillar generators.
04/20/2009 9:39 PM
Biogas is a mixture of Carbon dioxide, Hydrogen and Methane; but the concentrations of the different gases varies with production process and raw material of the process. Obviously the removal of some of the carbon dioxide may be necessary but in general provided the concentration ratios are maintained then the biogas can be used consistently to produce stable power - both electrical and thermal.
EditorGBAnalysts - Give a boy fish and he will eat may be for a day, but teach him how to fish and he will eat everyday.
11/19/2010 3:51 PM
CR4 Admin - Deleted Post
Vulgar/Rude/Improper Behavior: This post was deleted because it did not adhere to the behavioral policies of the site. Please review Section 14 of the CR4 Site FAQ and the CR4 Rules of Conduct.
Anonymous Poster (2); DVader1000 (1); editorgbanalysts (1); fishpipes (1); kkjensen (1); Massey 726 (1); Naif (1); PWSlack (2); ronwagn (1); wooliver (1)
