Guys - we are grit blasting mild steel with garnet, we can achieve the required profile and cleanliness. we are having problems with the high salt levels on the blasted steel afterwards (18ppm / 40 mg/m2) which is double what our client calls for.
Steel is degreased & washed before blasting, this gives us low levels prior to blasting. The Garnet salt levels are acceptable (<150 Micro Siemen/cm.)
Any suggestions to lower the salt level on the blasted steel. We cannot rewash or hydro / wet blast, it must be a dry grit blasting operation
