Previous in Forum: Die Failures for Injection Molds   Next in Forum: Box Dimension on a Mechanical Drawing
Cold Heading Machine for SS304 Components
04/17/2009 7:19 AM
I need help. What is suitable cold heading machine to manufacture hollow bush type components of SS304 material. Component dimensions are
collar dia - 10 mm, collar thickness - 2 mm , shank dia 5 mm , bore dia 3 mm
Is 2 Die 2 blow machine suitable. Taiwan make machine is acceptable.
Is induction heating necessary attachment of machine?
coldforging/ upsetter for SS 304 component
Good Answers: 243
Re: Cold Heading Machine for SS304 Components
04/17/2009 12:46 PM
What is your intended function for the induction heating with grade 304?
It (304) doesn't harden by heat treatment.
In order to anneal, it must be heated to 1010/1121C then QUENCHED IN WATER. Was this what you had in mind?
Were you thinking that you need to heat for hot forging?
304 (om reputable suppliers) is readily fabricated by cold working. It is extremely tough and ductile, meaning it will deep draw, bend, form and upset rather well.
Note, It will probably become slightly magnetic after cold working.
I'll let others describe their dream machine for production, I just want to protect you from the perils of induction...
milo
04/19/2009 12:28 PM
Hi Anil, The most suitable type of cold heading machine is called " Part Former ". 2 Die 2 Blow machine is suitable for your Collar Bush. Taiwan make machines are available at competitive prices. There are many Manufacturers in Taiwan. You can contact the following reputed companies : 1. Chunzu Machinery Industry Co. Ltd. Taiwan ( Web site : www.chunzu.com.tw 2. Jern Yao Enterprises Co. Ltd., Taiwan ( Web site : www.jernyao.com ). The best way is to send the part drawing to both the companies and ask them to quote for the suitable part former - FULLY TOOLED UP. Forget not to negotiate the rate & Terms. You do not require any induction heating equipment for this part. SS 304 annealed wire is good for cold heading. Milo has given you good advise - follow them. Good Luck. Rangasamy
Let noble thoughts come to us from every side.
07/28/2009 8:09 PM
A TWO DIE TWO BLOW HEADING MACHINE WILL NOT DO THE JOB YOU DESCRIBE
IF YOU WANT TO DO THIS JOB PROPERLY YOU SHOULD USE A 4 DIE NUT FORMER
BECAUSE THESE ARE MADE FOR SHORT CUTOFF LENGTHS AND ANYWAY YOU NEED
4 DIES TO POKE A HOLE PROPERLY YOU CAN'T DO THIS ON A 2DIE 2BLOW EVER
AND WHEN YOU SEND YOUR DRAWING TO ANY MACHINE BUILDER IN THE US OR
TAIWAN THEY WILL LET YOU KNOW WHICH MACHINE TO USE AND PROVIDE A PROGRESSION
Register to Reply 3 comments
Anonymous Poster (1); Milo (1); Rangasamy (1)
