Previous in Forum: Selecting the Right Pressure Gauge for a Motorized Pump   Next in Forum: artificial legs
Valve Ratings
04/17/2009 11:29 AM
I have a line pressure of 50bar and line size 10" i would like to install a butterfly high perfomance,
could someone help me
Good Answers: 101
Re: Valve Ratings
04/17/2009 2:46 PM
What exactly do you need help with?
Good Answers: 103
Re: Valve Ratings
04/17/2009 10:04 PM
What is your medium and temperature ?
You can procure valves to API 6D/ISO 14313 to the required pressure class (PN) and that must be OK.
Re: Valve Ratings
04/18/2009 1:17 AM
the temp is about 20 deg cel this is raw water,
Re: Valve Ratings
04/17/2009 11:31 PM
if you look for high quality butterfly ,you have to request the following:
1-triple offeset
2- Double Flanged or not as per your condition
3-body material: CF8M (BUT ACCORDING TO YOUR FLOW)
4-DISC MATERIAL: 316 S.S
5-SHAFT MATERIAL: 316 S.S
AND CHOOSE THE CLASS RATING ACCORDING TO YOUR PRESSURE AND TEMPERATURE
YOUR FLUID WILL BE AFFECTING ALL THE ABOVE MENTIONED PLEASE MAKE SURE
Re: Valve Ratings
04/20/2009 4:17 AM
Stand well away from it when it shuts...
mostafaalkholy (1); PWSlack (1); RVZ717 (1); sb (1); sikazwej (1)
