Previous in Forum: vector group   Next in Forum: DG Set for residential purpose-70kva
electrical
04/18/2009 11:58 PM
why is the earth pin in plug or socket bigger than the other two phase and neutral?
Re: electrical
04/19/2009 12:27 AM
The ground pin should be both bigger in girth and slightly longer.
You want the safety ground to have higher ampacity than the feeder, so that in the event of a fault and a malfunctioning breaker, the feeder opens (fuses) before the safety ground.
And you want the ground pin longer, so that the ground is the first connection made when connecting, and the last connection broken, when disconnecting.
These are all shock hazard-related issues.
Re: electrical
04/19/2009 12:29 AM
It isn't bigger, it's different.
You figure it out.
Re: electrical
04/20/2009 3:34 AM
So that the earth pin of the appliance cannot be inserted into the live receptacle in the socket inadvertently. The consequences would be quite shocking.
Register to Reply 3 comments
emc_c (1); lyn (1); PWSlack (1)
You might be interested in: Neutral Density Filters, PIN Diodes, IC Pin Probes
