Previous in Forum: Stimulus Grants: What's Available and What are the Deadlines?   Next in Forum: Position Measurment on Incremental Encoder, using FPGA
intrinsically safedetector
04/19/2009 7:12 AM
hi guys, i am looking for a smoke detector, that is to be installed in a hopper.
The hopper has hot air blowing through it from axial fan through an electric heater, Now my intention is to put a sensor beyond this point, so if any smoke arises in this hopper, it has to be detected and supply heater has to be cut. The smokedetector will be subjected to a temperature of about 170 to 200deg C.
Is it possible to get a Intrinsically safe smokedetector to work at these temperature, it has to drive a relay output so that we can shut the heater.
Tried to google, but not luck
thanks and regards
Good Answers: 18
Re: intrinsically safedetector
04/20/2009 9:04 AM
A quick Google search for, "intrinsically safe smoke detector" yeilded 14,700 results including this one:
http://www.tycoemea.com/english/pdf/datasht/fire/PSF129A.pdf
The most valuable of all talents is that of never using two words when one will do. ~Thomas Jefferson
04/20/2009 9:42 AM
Thank you sir, But i am looking for the one that can work at a temperature of 150 to 200 deg. I could only find the one that can work only upto 70deg only
Good Answers: 18
04/20/2009 10:49 AM
70 deg C does seem to be a magic number with these. What about adding a small vent at the top of your oven to direct smoke to a cooler location then installing the detector there?
04/20/2009 10:01 PM
Hmmmmmmnnn? It does makes sense to me, not bad Buddy, you have the technology I don't going to argue with ya' in this one. No Sir!
Hey nice idea I guess that will take care of it definetly.... Lock and Tag that Puppy for Safety and bring some orange juice with a all bunch of rags and a good 'tapping' (Cone Shape) Drill Bit just in case we never know. And nice safety Glass to Comply as well. And will be nice also to addapt couples of 'ThermoDisk' one for 'Operation' and another for 'Cut-Off' Max. allowable Temp. just in case as an Extra 'SafeGuard' feature there, OK you got it now! Tackle it Down and Succeess always...
Saturday OverTime Job,
MC
Register to Reply 4 comments
