Previous in Forum: Babbitt vs bearings   Next in Forum: GASKET PROPERTIES
What gets yer heat up faster
04/19/2009 11:55 AM
I'm looking for some feedback on what is the fastest way to heat a flat piece of pvc gel. the options I see are.
a. blow heat directly on top of it at max temp it can take
b. teflon coated hot plate on top of it at max temp.
I guess the real question is will a blower heat faster than a hot plate?
Thanks Gary
Logic will get you from A to B. Imagination will take you everywhere.
Re: What gets yer heat up faster
04/19/2009 12:10 PM
A radiation heater hot enough would do a good job too, without the risk of ending with a pvc coated iron. I'm inclined to say that a row of resistances arranged close to the piece in an enclosure sounds better to me. Is it a continuous process? Whats the size of the flat piece? Is it in an automated line? Any size, position, carrier or environmental constraints?
Humm... suspicious you are...
04/19/2009 12:24 PM
As usual, not enough information to give an informed answer.
Air stream and hot plate at same temp, hot plate wins.
Too many variables.
My advice, put it in the microwave. In the trade they are known as RF pre-heaters but any old microwave will do.
Good Answers: 266
04/19/2009 1:36 PM
The temperature of the hot plate has to be regulated or you will scorch the surface of the PVC. Same with blowing a heat gun on it. What is the purpose of heating?
A regulated oven would be better if you are trying to heat the piece completely thru.
04/19/2009 9:24 PM
You're right Lyn, to little info! I'll be as specific as I can.
.040" thick 4" diameter circle of pvc gel. on a teflon coated aluminum plate
the purpose is to cure it
curing temp 325F. as shown in original ?
I am trying to force cure as fast as possible w/o, as Ozzy mentioned scorching the surface. is the scorching point based only on high temperature?
are there other ways of curing than described?
Gary
04/19/2009 10:06 PM
Sorry, I have no idea how you "cure" PVC which is a thermoplastic.
04/20/2009 4:03 PM
Do you mean it just has to hit 325F or remain there for a time (not familiar with "gel" vs. resin)? Is out-gassing a problem?
How much cash do ye wanna blow?
options: vacuum, infra-red, or both
Half of everything in life is counter-intuitive,,, I'm not sure about the other half yet...
Register to Reply 6 comments
bhrescobar (1); Curious George (1); lyn (2); ozzb (1); riverrunner (1)
You might be interested in: Plate Forming Services, Hot Stamping Foils
