Previous in Forum: What gets yer heat up faster   Next in Forum: Air conditioning
8 comments
GASKET PROPERTIES
04/19/2009 2:08 PM
IF GASKET IS EPDM FOOD GRADE THEN WHAT IS THE m & y VALUES of gasket?
ARE TOSE SIMILER TO VEGITABLE FIBRE GASKET?
Re: GASKET PROPERTIES
04/19/2009 7:41 PM
You are out of your mind!!!!!!!!!
get a life....................
04/19/2009 9:01 PM
Sorry, impossible to determine what do you mean with that. Try to post a consistent question again, please.
Humm... suspicious you are...
04/21/2009 1:19 PM
Do you know a word Gasket
If yes try to get some knowldge about its properties from ASME SECTION VIII DIV 1
04/19/2009 11:43 PM
While I have never worked with either foodgrade EPDM nor vegetable fibre gasketing, I will offer this:
Foodgrade EPDM will have very similar gasketing characteristics of regular EPDM (synthetic rubber);
  • Below 75A shore durometer: m = 0.50; y = 0
  • Above 75A shore durometer: m = 1.00; y = 200 psi
Vegetable fibre is different from EPDM and has the following factors:
  • m = 1.75; y = 1100 psi
(Values from ASME Section VIII Div 1)
04/20/2009 1:04 PM
thanks
In ASME Section VIII Div 1, m & y values for EPDM Food Grade are not given.
From where you get these values for EPDM?
Is there any reference book?
04/20/2009 5:51 PM
I got those "regular" EPDM values from ASME VIII-1 as well, I assume that food grade (FDA) will have very similar (if not exact) characteristics.
You can always ask your gasket supplier.
04/20/2009 4:01 AM
Please turn off Caps Lock. Many readers consider the use of all-capitals rather rude.
05/14/2009 8:12 AM
I am currently experiencing a similar problem, when attempting to determine the m and y values for a "James Walker TC 500 14 x 14mm Nitrile ring bonded in PTFE envelope" gasket. I have consulted ASME VIII Div.1 and am unsure as to which values should be used. Any help in this regard would greatly be appreciated.
swifteng1
Register to Reply 8 comments
Anonymous Poster (3); bhrescobar (1); nbhide108 (2); PWSlack (1); swifteng1 (1)
