Hi all electrical engineers
We have a transformer rectifier unit (TR) about 20 years old powering an electro chlorinator unit. Original Spec was 1500A at 30V. As part of a plant refurbishment project this unit was sent away to local specialists for refurbishment and was returned to site about 2 years ago. It was reconnected to the power supply 6 months ago and demonstrated that it switched on and delivered power but was not fully tested. Recently we have tried to commission the plant but have found that the rectifier section overheats causing the plant to shutdown. The diodes appeared to be drawing different currents and on the specialists recommendation all diodes were changed. Now we have run it without causing a temperature trip at 26V / 1300A with a side cover removed to allow temperatures to be measured and obviously better airflow over the heatsink. On repeating the run with the side cover in place it tripped after just over one hour and it is obvious from the temperature measurements that the first run was on the limit. Can anyone tell me what might be the cause in a unit which we understand was able to deliver the specified current before it went away for refurb. The transformer section appears to be running cool. I am not an electrical engineer but would like to be able to ask the supplier some informed questions.
Thanks
