Previous in Forum: What is the best way to synchronize   Next in Forum: overheating transformer rectifier
8 comments
Galvanic isoltion
04/20/2009 4:12 AM
How can I get galvanic isolation in a low voltage circuit? (for example: current transformer, optoacoplador...)
How can I get galvanic isolation without using that (transformer)?
Location: Currently on break at home in Houston, Texas USA
Re: Galvanic isoltion
04/20/2009 5:09 AM
if you are working with either a control voltage or serial data, a fiber optic transmitter/receiver combination would provide the most isolation.
In the past, I have used this combination to remotely trigger a high-voltage power supply with good results and no fried circuitry at the trigger source.
04/21/2009 3:06 AM
Sometimes coupling the two 0V rails across an isolation barrier with a very high voltage capacitor can achieve the desired result. What are you trying to do?
04/21/2009 3:21 AM
What I have to do is to put galvanic isolation in a circuit where the voltage is chopped. I need this isolation to avoid the common mode noise. Now, I'm looking for different alternatives such as optoacoplers, isolation amplifiers... etc.
Can someone give me something like a list of the components or different ways that give galvanic isolation?
04/21/2009 4:18 AM
1.) Transformer.
2.) Optocoupler (with or without length of fiber). Difficult to achieve accuracy unless converting to a digital steam.
3.) Capacitor (won't get rid of common mode noise).
4.) Mechanical linkage (just joking).
5.) Radio (just joking).
Why don't you want to use a transformer?
04/21/2009 4:28 AM
Because I've to work with high frecuencies (f> 100kHz). Although I just find some that can work with much more.
But I prefer something smaller and less heavy, thanks.
04/21/2009 4:46 AM
04/21/2009 6:21 AM
Hi FrederikoII,
sorry, but your questions should have a bit more substance to give you the right answers.
1. What kind of a signal do you want to want to transmit, analog chopped (= different magnitudes) or digital (only one level, and if yes, which one, because digital is no longer 5V but nearly anything between 1 and 18V DC) ?
2. Whats the maximum frequency you need to transmit ?
3. Whats the distance (only inside a chip or more) ?
4. Whats the isolation voltage you need (not only the test voltage for xxx seconds but permanently allowed at which pulse shape) ?
5. Which I/O-capacitance will be allowed ?
6. If analog, which accuracy ?
7. Environmental conditions (e.g. optical RX/TX may be temperature depending which influences (5) ?
Regards Uwe
The sum of intelligence on earth is a constant. And the population grows and grows and .....
04/21/2009 6:43 PM
Regards.
Then "Opto-Isolator" is the option.
In open-loop control only single unit will work.
In Close-Loop control two are required.
Have a fine day !
Register to Reply 8 comments
FederikoII (2); Haajee (1); Randall (3); tropicalspeed (1); uweka (1)
