Previous in Forum: post weld heat treated   Next in Forum: bank tubes
ID INDUSTRIAL FAN
04/20/2009 7:13 AM
Dear Concern
please help me out that i have problem with ID Industrial Fan, i am using Spharical roller bearing on frent side of the fan, now i want to replace the spharical roller bearing with skf Carb bearing, will it give me better results or not?
waitng for your kind advice...
regards..
m.ifraz islam / nlb co.
0333-4349107
Re: ID INDUSTRIAL FAN
04/20/2009 10:14 AM
What is the root cause of the bearing failure? If you don't determine that, you will not solve the problem.
Is it a lubrication issue?
Installation?
Alignment?
Balance?
