Previous in Forum: ID INDUSTRIAL FAN   Next in Forum: What Specilisation to Opt. for a Mech. Engineer in his MBA
9 comments
bank tubes
04/20/2009 7:38 AM
hi, can anybody give the reason behind in expanding the boiler bank tubes which are connected to the drum in the bidrum boiler.
Re: bank tubes
04/20/2009 7:51 AM
Er, so that they don't leak between the tubeplate and the tubes?
Re: bank tubes
04/20/2009 7:55 AM
is there any other reason, why we don't weld in that portion
Re: bank tubes
04/20/2009 7:57 AM
is there any other reason.why we don't weld in that portion
Re: bank tubes
04/20/2009 8:01 AM
Er, so that the expanded tube and the tubeplate can be easily parted, to that the tubeplate doesn't need to be replaced as often as the tubes do, perhaps?
Re: bank tubes
04/20/2009 8:07 AM
can you please clarify theoretically. is there any calculation how much to be the tube expanded.its my opinion that it may due to the differential thermal expansion.also it may provide easy for repairing the bank tubes if any leakage found.
Re: bank tubes
04/20/2009 8:34 AM
also is there any standard in calculating the mandral size for expanding the tube
Re: bank tubes
04/20/2009 9:27 AM
Er, it needs to seal at the test pressure. An experienced boilersmith knows how much expansion to give a tube. Too little and it won't seal up. Too much and the tubeplate moves around, possibly unsealing adjacent tubes.
Re: bank tubes
04/20/2009 9:38 AM
sorry i didn't got the actual solution for my problem
Re: bank tubes
04/20/2009 9:48 AM
Then speak to a boilersmith.
Register to Reply 9 comments
