Previous in Forum: conveyor chain   Next in Forum: Alternate to Cadmium Plating
9 comments
Identification of Rubber Sheets
04/20/2009 8:30 AM
Hello,
We have a problem in our store and we are nor able of identifying the different types of rubber sheets (NBR, EPDM, Chlroprene, ...) we have.
Can anyone indicate me a simple method for the identification of the rubber without doing complicate chemical tests?
Thanks in advance
Re: Identification of rubber sheets
04/20/2009 10:08 AM
  • keep the delivered material together with its deivery packaging and order number so that the material can be identified from its purchase order details.
  • label the material upon arrival with the material details as stated on the purchase order.
  • Identify storage areas and dedicate a single area to a single material. Maintain rigorously the segregation within areas.
  • do physical tests. There will be a standardised hardness technique for determining the amount of 'bounce' in the rubber. Compare the tested sample to the manufacturer's standard.
  • is there a colour difference that could readily identify the materials?
  • is there a texture difference that could readily identify the materials?
  • is there a smell difference that could readily identify the materials?
04/21/2009 12:37 AM
can you give us your contact address , we want buy different types of rubber sheets
thanks
kalaiselt@yahoo.co.in
04/20/2009 10:19 AM
There is no simple method a layman can use to identify these materials.
Hardness, color, texture may help. What does your specification say? How did you buy them?
Follow the advice of PW.
04/20/2009 12:26 PM
We bought with european standards. In particular for our last project french standards (NF L 17-120 and 121 for NBR, NF L 17-131 for clhroprene and NF T 47-402 for EPDM).
Hardness is not a help because we have sevaral types of hardness in all the types of rubbers.
Color is not a help because all are black.
04/22/2009 1:05 AM
Guest has replied correctly. a burn test of a small sliver of the material should tell which is which. Some times a float test will tell one material from the other also. Floating in different fluids ie, alcohol, water, oil may be necc. good luck.
Bin there, done that, then done that again and again and now I forgot where I was.Is this what it means to get old?
04/22/2009 8:56 AM
As I stated in my original reply, "there is no simple method a layman can use to identify these materials."
Flame tests are only as good as the person performing the test and people with 20 years in the trade don't always guess right when burning the plastic. There may be distinguishing characteristics that an expert would recognize by burning the different materials, but not a layman.
Re: Identification of Rubber Sheets
04/20/2009 10:42 PM
Well, worse come to worse you might have to burn the one pcs each of the rubber sheet (which can be quite danger). Observe the smell, the smoke colour and even the fire itself.
08/29/2012 6:48 PM
Well correct!
There is no way to distinguish between different type of Rubber compound (Chloroprene, NBR, EPDM, Silicone, Nitrile, NR).
Burn test can also be concluded by a person having decades of experience in Rubber Industry.
The only way is lab testing.
11/25/2026 4:11 AM
Identifying rubber sheets by appearance alone can be difficult, particularly when different compounds have the same colour and similar hardness.
A few basic physical checks, such as density, specific gravity and hardness measurements, can help narrow down the possibilities, but they cannot reliably confirm the exact polymer type.
I would avoid relying on flame or burn tests as a simple identification method, especially when the composition is unknown, because they can release hazardous fumes and require specialist interpretation.
For reliable identification, FTIR analysis can help distinguish polymers such as NBR, EPDM and chloroprene. If laboratory testing is not readily available, the safest approach is to maintain supplier certificates, batch records and material labels, and keep different rubber grades segregated in storage.
For future purchases, requesting material test certificates against the specified standard can prevent similar identification problems.
irtubes
Register to Reply 9 comments
Anonymous Poster (2); irtubes (1); lyn (2); MIKE L. (1); PMVM-74 (1); PWSlack (1); Rubber&Polymer (1)
You might be interested in: Ceramic Sheets and Boards, Rubber Tubing
