Hello, first post here! I sure could use some guidance on a torque sensor that would go on a 3/4" round shaft (keyed).
Have 5hp motor, which operates a drive on a transformer for a gap. But I would like to measure the amount of rotational torque (plot a graph, torque versus gap position on the core, which is measured 0-100%). full gap open to close run may take 15 minutes
I believe the weakest link to be a pin on a u-joint that is spec'd to shear at 3050 in-lbs. so that would be the transducer upper end of measurement.
I have looked at transducers. slip ring, etc, I cant figure out what exactly best suits my need. I have called the sales people, but I am not getting a warm and fuzzy as to what else I would need to buy. I would like to buy the whole thing as a package if there is such a thing.
DAQ board must be used too?
I believe I need a datalogger program too. That program is pretty expensive. Couldn't this be dumped into an EXCEL spreadsheet though?
