Previous in Forum: Short Circuit Forces in Transformer   Next in Forum: Power Factor
calculation of MV Cable cross section
04/25/2009 2:12 AM
Dear Mr./Mrs
Kindly requested to direction me calculation method for determain of cabling cross section about 6.6KV electrical motor as following technical information:
Rating: 1200Hp/900Kw, 2 Pole, 6600V3 Phase, 50HZ
Short cicuit capacity: 31.5KA/3sec
Starting Method: Direct by combination vacuum contactor powered fuse
Vacuum contactor ABB Type VSC 400A
Power fuse siemens Type 3GD-250A
running current: 90.1A
Starting current: 500A
Starting time: 7Sec
Frequent start: 4/h
Re: calculation of MV Cable cross section
04/26/2009 11:11 PM
General variable that we have to know for calculating cable cross section are : load power, voltage,cable lenght and other variable. From your information there is no information about cable lenght. Because this information is needed to determine voltage drop of cable.This value is kept not more than 5%. But if your cable isn't too long, this calculation can help your problem.
Assume : using multiple core cable (3 core), pf = 0.8 ; derating factor = 0.7
1) Find the current rating, I = P/(sqrt (3)*V*pf) = 900/(sqrt(3)*6.6*0.8) = 98.41 A
2) After getting the current rating, refer to NEC code, you can multiply the current rating by 1.25, so we get 1.25*98.41 = 123 A.
3) See in cable catalogue for MV, current ampacity for this current. First of all, we can use 35mm2 with ampacity 130A, after multiplied with derating factor we get 0.7*130 = 91 A (This value is less than 123 A, refer to code we don't use this), with trial and error, we can find 70mm2 with ampacity 190A. After multiplied 0.7*190A=133A (this value is more than 123A,so we can use this size)
So, for this case we can use N2XSEFGbY 3C x 70 mm2.
Thanks
Reply to Forum Thread
