The rules and calculations are the same as the one used at lower frequency but the components are different. The capacitors will be film capacitors rated for the 10 KHZ. The switching of banks if needed is likely to be done by MOSFET or IGBT switches.
If this is for your induction heater or a motor drive, you should reconsider why you have to control the power factor on the output as it might not be a good idea to add anything there. Make sure that you know what you are doing as it can damage the inverter.
You r right.. I'm talking abt the M.F Induction heater. There is a Motor Generator set based Induction Hardening machine of 130kw.I need to match the power capacitor tappings(connected across the Output wires(2 wires). usually it is 60kvar) for every particular Job at output coil (around 60mm dia). the manual method of capacitor matching is taking much time & not satisfactory..
I wish to measure the PF on any meter, whether it's LAG or LEAD?. so I can increase & decrease the capacitance offline to get good heat output. I've tried analog PF meter by using PT & CTs. But, failed...
Pls Suggest Any Idea....
Regards,
"Strength does not come from physical capacity. It comes from indomitable will." Mahatma Gandhi
There are few power factor meters that will operate at these frequencies. The highest I have found was for 1 KHz and was very expensive.
I suggest that you use the zero crossing of the voltage through a comparator to trigger a A/D converter on a current sensor. The polarity and amplitude of the current sampled would be almost a function of the power factor. A few CMOS chips and a A/D converter with display driver powered by a battery supply should make a simple device. You could also program a microcontroller if you are up to it.
This is a nice term project for a student in electronics.
