Previous in Forum: manager -desgin   Next in Forum: Combustion air heat recovery
14 comments
Fillet weld by UT
04/25/2009 3:00 AM
I need to check the fusion of weld by Ultrasonic testing(The weld is not a full penetration weld).
Is it possible? How?
Good Answers: 120
Re: Fillet weld by UT
04/25/2009 11:27 PM
This is a mature discipline, and there are specialist companies that do this as their business. Call one in and pay their fees.
If you have the volume, buy the correct machine for the job.
http://www.google.ca/search?hl=en&q=welding+ultrasonic+testing&meta=&aq=0&oq=welding+%2B%22ultr
Per Ardua Ad Astra
04/26/2009 12:50 AM
Hi Arun, send more information about the configuration of the joint and the thickness that you have, some times is not possible to use UT for fillet welds. ( Plate to plate? Sockets?, slip on? Regards ADOLFO
04/27/2009 6:54 AM
Base metal 30mm thick, In that we need to weld 12mm thick plate verticallyto hold a hudraulic cylinder O/D 280mm.
04/27/2009 7:02 AM
Cylinder to basemetal weld is full penetration weld.that we can do UT. The supporting gussets are fillet weld(12mm thick plates)with cylinder and base plate 30mm thick.sufficient space is there for conduct angle beam insspection with 70 degree probe.(upto full skip)
Regards
Arun
04/26/2009 9:07 AM
Why would a non-penetration weld require UT?
04/27/2009 7:03 AM
there is a failure in the joint
Regards
arun
04/26/2009 12:01 PM
IVE NEVER HEARD OF A FILLET WELD GETTING A UT USUALLY IT ONLY GETS A VISUAL INSPECTION BY THE CWI(CERTIFIED WELD INSPECTOR)
04/26/2009 3:00 PM
it is not impossible.you can check U.T. only full penetration butter weld
04/26/2009 4:31 PM
This can be done. What must be used depends on the size of the weld and the thickness of the materials it is joining. Other considerations would be back-side accessibility of the joined pieces, whether the weld is single sided or double sided, what you are willing to pay for transducers, and the defect calibration standard you will need to manufacture.
Last is the most important consideration, the ability of the individual performing the inspection.
I'll be more specific in my reply if you can provide specifics about your application.
How can you be two places at once when you're actually nowhere at all?
04/27/2009 7:12 AM
thank you very much for your reply
Base metal 30mm thick, In that we need to weld 12mm thick plate vertically to hold a hudraulic cylinder O/D 280mm
Cylinder to basemetal weld is full penetration weld.that we can do UT. The supporting gussets are fillet weld(12mm thick plates)with cylinder and base plate 30mm thick.sufficient space is there for conduct angle beam inspection with 70 degree probe.(upto full skip)
For my knowledge one more thing i wanted to know even this is not possible,
A) How to carry out a ordinary FIllet joint test specimen (for WPS using plates 30mm,12mm thick, sizes 300x150
B) A fillet weld can be examined for its penetration depth by UT?
Regards
Arun
04/29/2009 9:00 PM
Arun,
Depth of penetration can only be approximated using straight beam from side opposite weld due to beam spread,which is determined by transducer frequency and diameter. The other limitations are in detectability which are functions of transducer frequency and surface roughness on either side of the plate, with inclusionary matter thrown in to keep it interesting.
I would not use 70 degree (surface wave) transducers for weld inspection unless you feel compelled to measure undercut with ultra sound. Better choices would be 45 degree and / or 60 degree, industry standards.
Test coupons of your description are common for bend and impact testing of fillets. The welded "Tee" coupon is usually sectioned into "Tees" of 25mm or less for destructive testing and acid etching for profile evaluation. From the leftover piece of this coupon is what you make your test standard from.
04/29/2009 11:31 PM
thank you very much Jerry. If i am not disturbing you, please reply!.
I am using 70 Degree probe for checking 12mm j groove joint.Is there any chance of false indications. Usually i see reaveled defects. Rarely can't. False indication may lead to show at what depth? generally it shows near to the surface isn't it?
Regards
Arun
04/27/2009 4:01 AM
it is better to use MPI or LPI for checking a fillet weld,since UT may give erroneous results.
siva
Hobbies - DIY Welding - pipewelder
05/01/2009 9:40 AM
I would suggest shear wave UTT for your fillet weld.
pipewelder
Register to Reply 14 comments
Anonymous Poster (1); Arun prakash (5); atorroja (1); aurizon (1); erector1 (1); Jerry New Hampshire (2); murat aliyev (1); pipewelder (1); siva1943 (1)
