I just completed an in-house project to recover heat from a thermal oil boiler exhaust and used this to heat up boiler combustion air. During commissioning, we noted the exhaust temperature drop 20 deg C, and combustion air heated up from ambient ( 35 deg C) to up to 70 deg C. Reduction in the boiler exhaust temperature indicates that the system has absorbed more heat, so the thermal efficiency should logically get better. But what we found happened was that the output from the boiler has somehow dropped. The thermal oil supply temperature dropped 7 deg C. Any ideas why this happened? We did not change any components in the oil burner ( 6.5 MW).
