Previous in Forum: Water Tower Demo   Next in Forum: Speed Governor for Steam Turbine
Connecting HDPE Pipes with UPVC Pipes
04/27/2009 12:09 AM
Can I joint 150mm dia. HDPE pipes with a 150mm dia. UPVC pipes. What types of connection will be appropriates. Kindly email me sample photos of pipes connection/ fitting
Re: Water Pipes different material
04/27/2009 1:49 AM
04/28/2009 7:38 AM
They have added a LOT of items since I worked there!
Been trying to visit their new location but don't get off in time to visit before they leave.
If anyone should know, ISCO and their technical team should be able to make anything work.
Sorry, not trying to pitch for them.
I have found that honor lies in doing the right thing even if no one is watching. Dignity lies in letting others take the responsibility and character lies in being able to smile as you walk away.
04/27/2009 3:54 AM
The coupler will be mechanical, as the two plastics cannot be readily welded together.
Re: Connecting HDPE Pipes with UPVC Pipes
04/28/2009 12:14 AM
You can use steep coupling.
04/28/2009 4:21 AM
Stepped couplings are quite usual way to do it. E.g. http://www.teekaycouplings.com/
Engineering Fields - Civil Engineering - Member Engineering Fields - Construction Engineering - Member Engineering Fields - Mining Engineering - Member United States - Member - Member Popular Science - Weaponology - Member Hobbies - Target Shooting - Member Hobbies - Car Customizing - Member
04/28/2009 7:58 AM
Almost any company that sells mechanical joint fittings will have what you want. The earlier posts gave you a good place tio start. Others are One-bolt, Mueller, Clow, Tyler-Union, American (AFC), Russell-Sigma, Griffin, Star, SIP Industries, and EBAA. Some of these may not make what you are looking for, but this should get you what you are looking for.
You cannot escape the responsibility of tomorrow by evading it today - Abraham Lincoln
05/03/2009 2:59 AM
you can procure standard flanges with identical bolt circle diameter for pvc and hdpe pipes and bolt them up using bolts of recommended size.
Register to Reply 7 comments
Anonymous Poster (3); Lab Rat (1); Old Coal Man (1); popoy12345 (1); PWSlack (1)
You might be interested in: Heat Pipes, Tube Fittings, Pipe Fittings
