in the split air conditioner,the cold circulating air fan is located in the closed room and the condenser and its fan are located outside the room so that the noise will be minimum.this condenser is connected with the cooling coil in the cold circulating air fan through gas pipe and power cable.
in this arrangement the cooler,cools the air inside the room and no fresh air is allowed in the room,unlike the window air conditioner,which has the facility of both venting and letting in fresh air.
is this good for the health of the occupants?
