Previous in Forum: Mysterious Object   Next in Forum: Arctic Sea Ice Melting Away
Expanding Foam Insulation
04/27/2009 8:14 AM
I'm doing research on expanding foam insulation for work. Does anyone know about the difference between open cell and closed cell foam insulation? What is the chemical makeup of the insulation? Also, does anyone know about the combustibility of this stuff? Test results would be great!
Good Answers: 73
Re: Expanding Foam Insulation
04/28/2009 1:06 PM
Just as it sounds, open cell foam allows flow through its cells and therefore does not make a very good choice in some applications. So, you need to include some comments as to your application requirements.
Glass fiber could also be considered as open cell but it is not a foam and it has very different properties but it can be compressed for insertion and then allowed to expand.
Chemical makeup and properties will vary widely for the temperature range you may need to cover. So, if you want good answers, you will need to include more information such as wall thickness, temperature difference, humidity factors, etc.
Reply to Forum Thread
