Previous in Forum: Indestuctible off the grid construction   Next in Forum: Dezhou Recinzioni Wire Fence Panel Inc.
MORTORQ Super Spiral Drive System
04/27/2009 8:46 AM
Good Answers: 123
Re: MORTORQ Super Spiral Drive System
04/30/2009 11:24 AM
What a wonderful design. I should run out and buy a set of these drivers so I can line them up next to my Phillips, Posidrive, Tri-wing, Torx, Security Torx, Clutch A, Clutch G, allen, security allen, Metric allen, Reed and Prince, square (Screwlox), Double Square, Triple Square, spanner tip,and of course flat tip drivers.
I hope they don't take up too much space, because I will need additional space next year when some tool designer decides that a 5 winged driver will add profits to his pockets an improvement in strength.
Bob
05/13/2009 2:18 PM
Hi Bob, first of all its Pozidriv you were close. Mortorq Super is presently being used by General Motors, Nissan, Mazda and soon to be on Chrysler and VW. You may even find this drive system in a bone screw soon. You are going to see lots of this drive in the future because of the steel savings in the fastener and it also gives design engineers more room to operate. If you ever need a bit just let me know. Thanks for the comment, Bill
07/15/2009 12:07 PM
I HAVE LOOKED AT ALOT OF NEW AUTO MAKES AND DO NOT SEE WHERE THIS MORTORQ IS USED. IF YOU SAY THAT THESE AUTOMAKERS ARE USING THEM THEN BE MORE SPECIFIC AS TO WHERE THEY ARE LOCATED ON THIS VECHILES?
Register to Reply 3 comments
Anonymous Poster (1); bob c (1); psdsaint (1)
